Last prowler will be build on 2-15-2002 at CAAP(CONNER AVE. ASSM. PLANT) home of viper and prowler for the last four years...
As for prowler being under powered not so..
Prowler has a 3.5 liter high-output SOHC 24-valve aluminum V6 - and for a lot of sound reasons: Packaging of people and roadability being the main ones.
But this free-revving 60-degree design cranks out enough suds (253 horsepower at 6,400 rpm) and yank (255 pound-feet of torque at 3,950 RPM) to get anybody's attention. It has an aluminum block with a forged steel crank bedded in the four main bearings. The heads and pistons are aluminum. It's been dressed-up, and heated-up slightly -- a less restrictive air cleaner, cast stainless steel exhaust manifolds that make tube-type headers look primitive, and EFI linear cam
throttle body for surprisingly quick, crisp response, so stay awake.
And keep your eyes on the rev counter -- because when you make use of the AutoStick(r) feature of the four-speed electronically controlled automatic transaxle and forget to upshift, an engine management system shuts down the fuel supply at 6600 RPM. You will notice the transition. You see this is the one automatic we install that doesn't have a mandatory upshift built in. You select a gear in AutoStick(r) mode, you shift it up or down as you desire. For the gearheads, final drive ratio is 3.89; individual gears are: 2.842 1st, 1.573 2nd. 1.000 3rd. and 0.689 (overdrive) 4th.
Engine Breathing:
Dual
throttle bodies induction, special exhaust
Transaxle:
Rear-wheel four-speed fully adaptive, electronically controlled automatic with AutoStick(r)
Curb Weight:2,838 lb.
NuttyGambler,
you are right you don't get it... just like GW not getting the T-bird..
compare to T-bird's curb weight of 3863lbs and 252hp@ 6200 rpm you tell which one is under powered...
NOW don't get me wrong I own a T-bird and two prowlers LOVE BOTH CARS..but just get the facts right..
Here is a picuter of last color build CANDY RED
