Another owner, A Do It Yourselfer:
This is the procedure and info for repairing a heat-
a/c problem on your Bird.
The symptoms were : Only hot air coming from any vents regardless of heat or
a/c setting.
The diagnosis is : Defective
Dual Coolant Flow Valve
The
part number is : YG378 --Order through : directfordparts.com List Price : $155.54 Their price : $91.61 w/shipping & handling $102.56
The Procedure :
1. You will need to get the vehicle up on ramps in order to drain the coolant.
2. You will need to remove the plastic shielding under the vehicle using a 5.5 mm socket.
3. You will find a coolant draincock on the bottom passenger side of the
radiator. Take an adjustable wrench or pliers along to loosen the draincock. Make sure you have a good sized drain pan to catch the coolant in as it will deflect off a few item on the way into the pan.
4. Remove the engine air cleaner outlet tube. I found it easier to remove the total air box system. Using an 11mm socket for the nut on the far left side of the air system. You will need to loosen the screw bracket for the air tube attached at the
throttle body. Remove the top of the air cleaner box and then pull the clean air system out.
5. Release the clamp and disconnect the upper
radiator hose.
6. Release the hose clamp and disconnect the hose that runs from the control valve to the upper
radiator hose, where it attachs to the upper
radiator hose. It is easier to remove this hose from the control valve after you remove it from the vehicle, then attach to the new control valve. You can then rotate the upper
radiator hose backwards out of your way.
7. Release the LH heater hose clamp and disconnect the hose. Make sure you move the drip pan under this location to catch coolant running out from the hose.
8. Release the RH heater hose clamp and disconnect the hose. Position bothe heater core hoses backwards to prevent further leaking of coolant and to get them out of your way.
9. Remove the
dual coolant control valve bolt with an 8 mm socket. It will be easier if you have a very long extension.
10. Remove the
dual coolant control valve.
11. Remove the electrical connector, pushing the red clip upwards then using a screw driver to remove from the control valve.
12. To install reverse the removal procedure.
13. Fill the engine cooling system.
