Ford Thunderbird Aluminum Radiators 1955-2005 | Ford Thunderbird forum club group 1955-2005 models
Forum Moderator
Staff member
1,224
Ford Thunderbird Full Aluminum Performance Cooling Radiators. Please double check that the part fits your model/engine. Feel free to post replies with your installation photos/instructions below.
1955-1956-1957 Ford Thunderbird Y-Block Aluminum 3 Row Performance Cooling Radiator- Ebay Link
1958-1959 Ford Thunderbird Frostbite Aircraft Aluminum Radiator 3 Row- Ebay Link
1960-1961-1962 Ford Thunderbird Ebay Link
(please reply below if you find others)
1961 1962 1963 1964 1965 1966 Ford Thunderbird- Ebay Link
Note: 1961-1963 & 1964-1966 had different fan guards, but this will fit with both.
For 1964 1965 1966 Ford Thunderbird Full Aluminum Performance Cooling Radiator- Ebay Link
1967-1968 4 ROW Aluminum Radiator for 1967-1968 Ford Thunderbird Ebay Link
1969 Ford Thunderbird Aluminum 8 Rows Radiator Transmission Oil Cooler & 7" Cooling Fan Kit Universal Ebay Link
1972-1973-1974-1975-1976-1977-1978-1979 Ford Thunderbird 3 Row Aluminum Radiator- Ebay Link
1980-1981-1982-1983-1984-1985-1986-1987-1988 Ford Thunderbird Radiator - Ebay Link
1994-1995-1996-1997 Ford Thunderbird Radiator- Ebay Link for 3.8 V6 // Ebay Link for 4.6 V8
2002 Ford Thunderbird Radiator - Ebay Link
Hydraulic Cooling fan which was only in 2002- Ebay Link
2003-2004-2005 Ford Thunderbird Radiator- Ebay Link
If you need a radiator sticker decal for the 2002-2005 check out this post- https://forums.fordthunderbirdforum...engine-radicator-fan-decals.11711/#post-71853
looking to replace the radiator on my thunderbird. i was looking to upgrade to a full aluminum one to remove the issue of a weak plastic under high heat. but they only seem to make them for the 4.6L, i have the 3,8L so my question is, are the radiators interchangeable throughout both engines or would i need to find something else for the v6? if anybody knows please let me know!! thnk you!!
This is a common misconception. The "plastic" being weak. The reality is, these radiators typically outlast aluminum and are more resistant to cracking and are not subject to corrosion. Because of the harsh operating conditions, the radiator tanks are made from glass-reinforced nylon, a plastic that features a high-softening point. The high-softening-point nylon plastic is what helps the plastic radiator tank withstand the pressure and temperatures involved.
Our OEM Jeep radiator lasted 22 years. Folks that replace with Aluminum report failure after a few short years or even months.
With that said there are links above for the V6- https://www.ebay.com/sch/i.html?LH_...teid=0&campid=5338236430&toolid=20008&mkevt=1
So I belive a 55 has a air cooled transmission. I need to get a new radiator for my bird. If I buy the one with transmission cooler lines can I cool my transmission or would I need to replace the transmission. I belive in 56 they put a cooler in for the transmission.
On 1955 and early 1956 Thunderbirds, with a Ford-O-Matic transmission, the torque converter is air cooled. The air enters the converter housing through a removable duct on the left side of the housing. A screen in the inlet duct filters out gravel and road dirt, and can be removed for cleaning and inspection. Fins on the outside of the impeller housing draw air into the converter housing. A baffle directs the air over the entire converted surface. The air is exhausted through an outlet on the side of the converter housing.
Inside the Converter Housing
Outside the Converter Housing
I noted a minor leak in the passenger-side (plastic) inlet tank on the radiator. So, it's time to replace it!
I see that the OEM radiator (H2MZ-8005-AA) is NLA from Ford; only aftermarket units available. I'd prefer a fully-aluminum radiator with tig-welded aluminum tanks. However, the only ones I am finding are on ebay and Amazon
Thought I'd ask the group if you have replaced your '03-'05 radiator with an aftermarket unit, and which brand you went with, and your experience with it. If anyone has used one of these fully-aluminum radiators from ebay/Amazon, I'd definitely like to hear your feedback.
I am looking at a radiator from Stillwell Ford on E-bay- has anyone had experience with this seller or generally buying parts on E-Bay ?
All sellers on Ebay have ratings and reviews/feedback. Read them. Ebay is a 30 billion dollar company with buyer protection, so there is no real reason for concern when buying on Ebay.
I've been looking to upgrade my radiator setup from the 17" to the 19", but apparently none of the suppliers have them anymore?
Do you still have thus setup available, or did you finally sell it off?
Frank
