2004 Tbird air conditioning blows hot air
This might help from a 2008 and 2017 Thunderbird Forum posts:
"Don't jump and spend money on something that may not be correct. I just checked on another owner that had the same problem [Tbird A/C blowing hot air]:
He said, "The coolant control valve is located on the passenger side of the radiator shroud. You will find three hoses connected to it, two of those hoses running to the heater core, the other routes to the upper radiator hose. This coolant control valve has two electronic actuators that divert the coolant in the appropriate manner. When they malfunction you will get only HOT air blowing from your vents regardless of which temp you set, whether A/C is on, or where you direct the air to come from. The part can be ordered from Direct Ford Parts for $102." -
Installed it himself. Not sure if this is your problem, sounds like it. But, always refer to the search function.....There's a wealth of info there for you."
Retrieved 5 July 2017, from http://forums.fordthunderbirdforum.com/threads/a-c-blowning-hot-air-help.3549/#post-30456
See also, Doering, R., Horne, T., Horne, T., & Horne, T. (2017). 2005 T'Bird AC Only Blows Heat. Ford Thunderbird forum covering all models 1955-2005. Retrieved 5 July 2017, from http://forums.fordthunderbirdforum.com/threads/2005-tbird-ac-only-blows-heat.5280/#post-32648
My 2004 just started blowing hot air out of the air conditioning. I just bought this car! Does anybody know what it could be or have the same problem? Thanks!
Feel th e hoses/tubes coming from compressor. IF one is cool, go for the electronic switch. IF not, try the rechagring idea.
BE sure the compressor clutch engages and the compressor is running
Thank you so so much! I really appreciate it! I certainly don't want to dump money into a problem and it doesn't get resolved. As a woman of limited knowledge of this, Mechanics sometimes try to take avenge of me. Thank you!
yes i have same problem
My 2005 just started same problem, blowing only very hot air. Dealer says the entire electronic controls system must be replaced, cost of over $2200! Has anyone had a similar problem? Does anyone have any experience requesting some help from Ford Motor Company for the cost of this? My car only has 30,000 miles!
Don't know what tests your Dealer did to arrive at this conclusion. I do think that they are wrong.
A very common problem with the 02-05 Birds is the air conditioning system suddenly putting out nothing but hot air. When the cabin temp is set to a temperature the system holds that temp by mixing hot air with the ac air. The correct amount of hot air is controlled by how much & how long hot water from the radiator mixes in the heater to hold the cabin at your pre-selected temperature.
This is done by the dual control heater valve which is located on the passenger side about half way down on the radiator. You can see it clearly by just looking down in that area. You will see a wire harness & 3 small hoses going into this valve. This valve fails; sometimes always closed, sometimes always open. In your case it has failed open allowing hot water to pass into the heater all the time.
If you have some mechanical/tool usage experience you can change this valve yourself, it isn't difficult. Just a awkward place to get into as well as many sharp edges. If you take it to a mechanic it should be about a 2hr job and the valve can easily be located at most auto parts stores as well as a Ford or Lincoln dealer.
Lincoln dealers know more about the engine, cabin temperature controls & transmission than most Ford dealers as the 02-05 T-Bird has many common parts with the Lincoln LS.
I think they are trying to rip you off. Car Care clinic is trying to charge me $250 for parts for a heater control valve and 370 labor plus 80 for diagnosis
Well we here already did the diagnosis for Car-Care. Just tell them to replace it. Or better still go buy the part your self & have any good local mechanic/ independent shop change it out for you. This too will be less expensive than Car-Care
hello all i have a 2003 t bird and the air conditioning just stopped the other day i do not have a owners manual for the car and am reaching out if there is anyone out there that may know of a fuse or relay that goes bad the system is holding a charge the compressor will not kick in , i want to take the car to the woodward dream cruise next month so it needs to be fixed any help would be great .
Hi Fran,
There are a number of things it could be but I wanted to alert you to watch out for erroneous information on YouTube regarding how to recharge the compressor where the person mixed up the high & low connections. I also ran into another issue where besides being low on refrigerant, it was switching from blowing cold to blowing hot air. This baffled several "experts" until one steered me to an old Radiator repair shop where it was fixed with a relatively inexpensive part from Ford. (that guy's mother owned a retro bird like ours) Strongly suggest you get a copy of the manual for the simpler stuff.
Steve809
Hi Fran,
Just had the same problem with my 2003. The local Ford dealer diagnosed the problem as a bad compressor. After replacing the compressor the a/c works great, unfortunately at a cost of $1200.
cdbintexas
Well-Known Member
Fran, My 2004 AC did the same thing before hot weather arrived in Dallas. Coincidently I replaced the radio which necessitate unpluging the AC/Heat Control panel. That reset my MCU and the AC now works like a champ. Your mechanic can look up the self test error codes reported by the control panel when you press OFF &FLOOR at the same time followed by AUTO within 2 seconds they will be displayed. The online manual will tell you what each means. Have Fun!
sir i tried to see the test error codes , hit the buttons the way you said and zip did it with car running and off and also with key in on pos ???
For anyone with AC problems I want to share my story. Purchased a 2004 with 6,500 miles (10/10/2019). Put 400 miles on the car and the first time I parked outside and went for a drive, my AC felt cool on driver side and warm on passengers side. From looking at forums I knew it had to be the DCCV. I order OEM Valve and installed it. Guess what? Still warm on passenger side. After scratching my head for a day or so, I decided to take to my repair shop. Told them to evacuate and recharge AC system. After mechanic finished, I was told the system had only 4 oz of charge. My AC now will freeze you out, the mechanic gave me the temperature difference between the two sides before and after. There was a 10 degree difference before the charge and a 2 degree difference after the evacuation and recharge. Was told the placement of ac coil make the difference in side to side temperature. The lower the charge, the bigger the difference in temperatures. Was told no sign of any leaks, just slow loss over the years. Hope this helps someone!
CBBIRD
2005 Steel Blue Tbird
Yes, I had to replace the compressor and control valve two years ago on my 05 to get my air back. I was not happy, but the car is 15 years old.
