Installing a hard access between an Apple IPOD and a 2004 Thunderbird radio.
http://www.autotoys.com/x/product.php?productid=9416
FORD 2004+ IPOD ADAPTER [PIE FRD03-POD/S] (FOR USE INTO 16 PIN SAT ...
1. You will need a 5/16 wrench for the negative battery cable, a
7mm nut driver for the top down panel removal, a 8mm nut driver to remove the
radio and flat head screw driver with masking tape over the end to remove various panels.
2. Placed car on level surface and set parking brake.
3. Lowered top to get easier access to work with if you desire.
4. Eject all
CD's and move the shift to “D4” all the way back to not interfere and protect the shift from damage.
5. Open trunk and remove negative battery cable. Leave trunk open.
6. Remove the panel that is in front of the shift console. “Step one in diagram.” If you are very carefully with a wide screwdriver end protected by masking tape pry at the top corner edges, the panel will come off. “Step two and three in diagram”. NOTE I had difficult removing this panel. At a later step you will need to remove the center console to install wiring going to the IPOD. I suggest you remove the center console before removing the panel in front of the shift console. Lift up on the front corners of the center console and it will pop off. Lift up on the back of the console and it will come lose. Put the center console out of the way.
7. There are two
7mm bolts on the bottom of the lighter/
convertible top button panel. Remove these and the panel will come right out “step two of the diagram”.
8. Now take a wide blade screwdriver with a piece of masking tape on the end and pry out the BOTTOM left and right corners of the air conditioner vent control. There are no hoses to worry about it just wedges into the ducts to the rear of the vent. The
plugs can be easily removed if desired.
9. The next two 8mm bolts are on the bottom of the
air conditioning control module “Step five of the diagram”. These are also removed. You will then notice two 8mm bolts on the top of the
radio “Step five of diagram”. Remove these, cover the shift lever and center console with towel to protect it from the
radio and the
radio will come right out “Step five of diagram”.
10. There is sufficient cable length to set the
radio on the towel on the shift console. ANOTHER WORD OF CAUTION besides being careful of not scratching the shifter knob is to be very careful to not drop or jar the unit to hard. The
CD reading head can be bounced out of position if it is jarred or banged to hard.
11. Picture DSCF0005 is a picture of the
wiring harness that comes with the IPOD module. Disconnect the factory 24-pin and 16-pin (if present) connections from the rear of the
radio.
12. Connect the 24-pin and 16-pin connectors of the interface harness into the
radio.
13. Reconnect the factory 24-pin and 16-pin (if present) connectors into the mating connectors of the interface harness.
14. Connect the 10-pin Molex connector of the interface harness to the mating connector of the interface black box. I ran the 10-pin Molex connector down through an opening below the
radio to just in front of where the seat heating controls fit. Now you are ready to work the
radio back into the area. It is difficult with the added
wiring harness. You will need to arrange the
wiring harness to make room for the
radio to fit. Reinstalled the four 8mm bolts to hole the
radio in making positive that you have a good tight fit. I had to try several times to get the
radio and harness to fit so I could tighten the 8mm bolts down.
15. Connect the 10-pin Molex connector of the interface harness to the mating connector of the interface black box. Place a strip of Adhesive Velcro strip to the back of the black box and to the flat module in front of the console. Connect the male 13-pin DIN of the 4-foot dock cable to the female 13-pin DIN of the interface black box. Fasten interface box using the Velcro to where you put the adhesive Velcro on the car.
16. Route the 4-foot dock cable to the iPod location (i.e. center console or glove box) do not connect iPod yet. I ran through the center console tunnel and brought it up through the emergency brake escutcheon. This is why you needed to remove the center console.
Cup holder is a good place to hold the iPod.
17. Reconnect the negative battery terminal.
18. Note: For best synchronization between iPod and
radio,
radio and IPod should both be ON.
19. Connect the routed 4-foot dock cable to the iPod. A symbol showing your iPod batter is being charged will show next to the battery indicator.
20. Wait a few seconds while the iPod interface searches for all the playlist(s).
21. Reinstall the center air register panel (step 4 in diagram).
22. Reinstall the power panel with the two
7mm bolts (step three in diagram).
23. Reinstall the Lower instrument panel finish panel. I found it easier to do if I did this before reinstalling the center console.
