I
intensifi
- 10
- 2004
I acquired:
1 Kenwood DNR1007XR
1 iDatalink/Maestro SW (ADS-MSW) steering wheel control adapter
2 Kenwood CMOS-740HD cameras (MUST use REAR and FRONT/DASHCAM leads on headunit)
1 SiriusXM adapter (SXV300)
2 Metra harnesses (70-5521 [only works for 2004 & 2005] - cannibalized one for more pins/wires for steering wheel control - pin 18). DIFFERENT HARNESS FOR 02 & 03.
1 Metra relay (E-5000 - negative triggered on reverse light)
1 Axxess resistor (AFDI-5V - stop amplifier pop on startup)
1 USB3/HDMI Adapter (Willizter 26121600 - take over cigarette lighter spot)
1 Double Din adapter (PAC Audio LLSK582)
1 Roll of pinstripe tape (flat black to cover the Kenwood branding on the edge of the headunit. Wrapping the entire outer frame to make it look nice/OEM)
I bought the big ticket items from my local audio shop (Audio Design in San Jose, CA - highly recommended) and the items they didn't have in stock from Crutchfield. Crutchhield provided great wiring diagrams!
The car is remote from me. I bought it for my daughter who is out of state. I wanted to prep (test and solder) everything here before shipment to make it easier on the installer.
So far so good!
When I attach the reverse wire to the negative (ground) terminal on my power supply, the rear view camera pops up. Once I remove it, the forward camera pops up for 5 seconds. The forward camera can be seen at other times by holding the Nav button down (used for curbs while parking!). Wireless CarPlay is working fine.
The Kenwood has a speed sensor wire. It looks like that and the power antenna wires are the only ones I will not be using.
I replaced the default Kenwood boot up screen with a Thunderbird image I "liberated" from the online version of the Quickstart guide that came with the car. Instructions on how to swap boot images are available on the Internet. I include the new boot image png file below. To use it, you will have to convert it to bmp (16 bit RGB) format (I used GIMP - Note: this forum would not accept the bmp file I created - otherwise ...).
I will be keeping the original headunit in case it needs to return to stock.
My thought is this will take an awesome car and update it for the modern era (and become safer)!
I am happy to answer any questions!
View attachment IMG_2389.mov
1 Kenwood DNR1007XR
So far so good!
