R
RTBRD_aka_jodrod
UPDATE EMAIL ADDRESS
This was suggested by DavidA quite a while back and now that time has passed and there are more Birds on the street, it might be time to start it.
One hates to think about any problem with their new car, TBird or otherwise, but it is now becoming apparent that there are some problems arising.
I am going to start another database to list these problems and their resolutions. Since this is the first pass there will be some modifications to the format but this will serve as a starting point.
I would prefer that you keep your descriptions short and to the point but include enough information to be descriptive.
Since I had a problem early on with the fan module in my car, I will use it as an example.
You can post here or send the data to: res08cfi@*********** and I will include it in the database.
I am open to suggestions as to how to improve this listing/database. As I gather more data I will probably break down the listing into problem areas (HVAC, stereo, top, NVH etc.).
The file is located at Problem/Problem Resolution Listing.
FYI - For a listing of the UBB codes goto UBB Code Listing.
- VIN: 102532
- Incident Date: 12/16/01
- Milage: 4487
- Problem: Car overheated
- Symptoms: Smelled steam, temp guage was maxed, engine went into preservation mode, noticed several days before that the heater would not put out heat
- Resolution: Dealer replaced the fan module
- Cost: Warranty, none
