Baby Blue
- 0
- 2003
My 2003 Thunderbird Premium is having several issues that have yet to be diagnosed. It has starting problems. It will start and die repeatedly. Sometimes turn over but not start. However, if you turn the ignition enough it will eventually start. During the cold weather it doesn't even want to turn over on most turns of the key. When you finally get it running it has several other symptoms: the power steering doesn't work properly (sometimes it works, sometimes it doesn't, and will go in and out intermittently); the turn signals do not work properly (flash on an off but at odd intervals). I sent the FEM in for a rebuild, but they said it checked out fine. I have had the PATS system reset. I have had new coils and plugs installed. I have had the ignition cylinder changed. But nothing has helped. The problem is worsened. Does anyone think this could be the ECM? I am getting desperate for a fix.
