While I’m want to swap my 1993 Miata LE for a Thunderbird , today I drove a one owner 2004 Black with red and black interior, really drove out nice, well taken care of, will put it on a lift Monday morning, anything I should be looking at while I consider this car? Thank tou!
I have a 2004 Merlot Thunderbird that I purchased last year. My wife and I took it on Route 66 from Chicago to California and back home to Ohio via the northern route. We were on the road 28 days and 6,300 miles. There something about driving a Thunderbird on Route 66, on a sunny 75 degree day with the top down that can’t be described. I also have a 1955 Thunderbird that I drive locally 1,000 miles per year. As you can tell I would rather drive and enjoy my cars than just let them sit in a garage and look at them.
When I was going to purchase my 2004, I drove it normally and then aggressively to make sure there was no delayed transmission engagement at low speeds and turning corners, and there were no hard jerks of the transmission engaging.
Check out everything electrical, the electronic modules are big ticket items. Make sure the dash lights and
shift indicator lights work, if they don't the the Front Electrical Module is probably defective.
Make sure the
ignition coils and the
wiper motor bracket seal campaign were performed.
You may want to check and make sure the latches for the top unfasten and fasten and don't forget to operate the
convertible top. The
tonneau cover for when the convertible is folded down and the
hard top are included with the car.
Make sure the car comes with two sets of keys; a replacement set keys from Ford is costly.
Put the vehicle on a lift so you can check the brakes, tires, suspension, and the underside for any leaks or damage. Deteriorating suspension
bushings are common.
Connect a scan tool, (if you have one), to the car's Data Link Connector so you can check to see if there are any fault codes in any of the control modules.
