Headlight Assembly Housing & Halogen LED Bulb Replacement 2002 2003 2004 2005 Ford Thunderbird | Ford Thunderbird forum club group 1955-2005 models
Forum Moderator
Staff member
1,130
Headlight Assembly Housing pair available on Ebay click here
Headlight Assembly Housing Available on Amazon- Pair of lights click here
Drivers Side or Passenger's Side
Replacement headlight bulbs while you are doing this- https://amzn.to/2WuHbZh
Replacement 3457A turn signal bulbs while you are doing this-
Incandescent- https://amzn.to/35y7FgF
You can also purchase a Meguiar's G2980 Heavy Duty Headlight Restoration Kit to clear up your existing housing.
Related post- Tail lights aka tail lamps- https://forums.fordthunderbirdforum.com/threads/ford-oem-02-05-thunderbird-tail-lamp-assembly-right-5w6z13404a-left-5w6z13405a-taillight-tail-light.11162/
If you need a headlight switch, see this thread- https://forums.fordthunderbirdforum.com/threads/2003-headlight-switch-replacement.13588/
We do not recommend the use of cheap LED Headlight conversions in halogen housings! This can be dangerous and illegal in some places! Members have reported lawsuits as a result of accidents and LED headlight conversions.
There is one company that makes a LED upgrade headlight bulb call VLEDS, please make sure they meet your laws! Click here for pricing.
Installation Video-
My plastic headlamp covers have melted from the inside. Has anyone else out there experienced a similar problem? I thought maybe a previous owner had replaced the bulbs with brighter ones, but that is not the case here as the bulbs are what the owners manual specifies. I don’t want to replace the covers if this is just going to happen again. Thanks in advance for any assistance.
TC
My plastic headlamp covers have melted from the inside. I thought maybe a previous owner had replaced the bulbs with brighter ones
Purchase new housings and the correct halogen bulbs using the links above. They probably tried to put in some sort of cheesy LEDs or something else in the housing.
While taillights seem almost impossible to get for under $500-1200+ each, there are sellers with brand new aftermarket headlight assemblies for $250 a pair.
My headlights have the typical amount of 60K miles/18 years on them, and before I did a polish on them to remove scratches wanted to solicit opinions.
