If you are having trouble with your cooling system on your 2002, 2003, 2004 or 2005 Ford Thunderbird here are some useful parts used in the repairs. Note, a 2002 Thunderbird has a different thermostat housing than 2003-2004-2005. The water pump & thermostat are the same. You can upgrade the thermostat in a 2002 Thunderbird to aluminum. I believe only plastic is available for 2003-2005 Thunderbirds. The plastic thermostat housings often need to be replaced every 5 - 7 years.
Several people have reported issues with the paper gaskets on the aftermarket water pumps. The water pump itself is okay, but you need the upgraded gasket sold separately.
2002-2005 Thermostat-
Purchase Link- https://amzn.to/2Y7ccEl
2002 Thermostat Housing Kit Assembly Aluminum Upgrade Kit-
Purchase link click here
Please note, this is an "unofficial upgrade" from the cheap plastic bell housing that member @Wfg3 discovered. They seller does not show the part as compatible, but it works as noted in his post here- https://forums.fordthunderbirdforum...work-in-2002-2005-thunderbird.8852/post-56177
2002 Thermostat Housing Kit Assembly (Plastic)
Purchase Link- https://amzn.to/2MZYKMp
2003-2004-2005 Dorman 902-903 Thermostat Housing Kit Assembly- (aluminum upgrade is not available to our knowledge)
Purchase Link- https://amzn.to/2YElNBR
OEM Motorcraft Part 3W4Z8548AD (Recommended when available)- Purchase Link
All available thermostat housings, some include coolant reservoir- Purchase Link
Housing Gasket (If Need) Amazon Purchase Link - Ebay Purchase Link
Coolant Overflow Tank for 5W4Z8A080AA
Purchase Link
The Motorcraft factory tank is over 200.00! Purchase link
WATER PUMPS.
The water pump and the gasket is the same on 2002-2005, but the thermostat housing is not!
2002-2005 Pro Gasket- This is better than the paper gaskets included with the water pumps
Purchase Link
Motorcraft PW448 2002 2003 2004 2005 Water Pump OEM-
eBay purchase Link or Amazon purchase link
Aftermarket 2002-2003-2004-2005 Water Pump (don't use the paper gasket)
Purchase Link Amazon- https://amzn.to/2N0h3ks or eBay purchase link
2003-2005 Water Pump + Plastic Thermostat Housing (Housing won't fit 2002)
Purchase Link
2002 Ford Thunderbird Radiator - Ebay Link
Hydraulic Cooling fan which was only in 2002- Ebay Link
2003-2004-2005 Ford Thunderbird Radiator- Ebay Link
Purchase Link
WATER PUMPS.
Purchase Link
Purchase Link
