edward301
- 456
- 2002
Last September I bought a 129k mile T Bird to store for parts for my two 2002 T Birds that are
low mileage. Today I decided to go through the car and look for any issues so I knew the
overall condition of the car. The car is tired from being parked outside, and who ever worked
on the car did not bother to put everything back together properly, but otherwise the car is
in very good condition.
The lower bolt for the valve covers is missing on each valve cover, so that tells me the cops have
been worked on. I will say the car sat for 5 weeks, but it did start right up. Thought the battery
would be weak.
No oil leaks, ball joint boots good, looks like there were all replaced some time ago. The thermostat
housing looks original, and no cracks. AC looks like it is starting to leak some, but works. I hooked up
a code reader, and only came up with a code P0442, a small evap leak. Thought there would be more
codes. Check engine light was not on either.
Engine idles great, good, smooth, and strong. Transmission shifts great also. Dash lights, and shifter
lights do not work, do not know if lights are burnt out, or if FEM is starting to go bad. Everything
else the FEM controls, works fine. Even radio works, top goes up and down good. To my surprise
the hydraulic fan works perfectly, is not even leaking. Thought with this many miles it would at
least be leaking, but not yet.
Found a place to store car at my warehouse inside, so going there soon.
would be weak.
