J
jack-in-sac
- 215
- 1957
In this situation a temporary check can be a good idea. The smaller pulley if moving coolant through the radiator faster does not make things cooler. The coolant moving faster just returns coolant that is less cooled by less time to give off heat from air flowing across the radiator surfaces.Do yourself a favor remove the thermostat and drive the car with out it let it idle and drive it on a hot day the car should run at lower temperature and if this fixes your problem put a 160 degree thermostat in it and be done. Y blocks don’t have any overheating problems they have been used in cars and trucks up to 1964
