B
Brad
UPDATE EMAIL ADDRESS
I've recently had the displeasure of having to put the spare on my car. Does anyone know of a way to fit a full size tire into the trunk and still be able to close the trunk?
I ended up having to deflate the full size tire in order to get the trunk closed. When I hit a bump it fell down into the spare tire hold area.
If you ever put the spare on, be very carefull to make sure the wheel is fully mounted...It's very tricky to get the wheel fully onto the studs. If you're every desperately bored, I'd recomend you try changing a tire at home in your garage so that you know what you're in for on the road....Yes I know about the motor club, and Ford roadside assistance, etc, but you never know when you may need to do it yourself.
