Forum Moderator
Staff member
- 1,130
- 2003
There are 2 kits available for the Ford Thunderbirds . One will be for the stock distributor that will fit the 1955-1956 Y-blocks. Some people replaced the stock distributor with the newer distributor because it was a better distributor.
The other kit is for the 1957-1974 Ford 8 cylinder distributors.
The way you can tell the difference is the 55-56 stock distributor has a round rod coming into the distributor from the vacuum advance unit, it takes Pertronix Electronic Ignition Kit #1282. Purchase on Amazon here or Ebay here.
If the system is a 1955 6-volt it takes Pertronix Electronic Ignition Kit #1282P6. Purchase on Ebay here.
The 57-74 distributor has a flat rod coming in from the vacuum unit, it takes Pertronix Electronic Ignition Kit #1281. Purchase on Amazon here or Ebay here
