Thanks for your reply Bill:
I found more than one thread and do not know which ones you could/could not open. So, I will copy them here. If no help to you, at least they will be here for others:
I have a 2002 T Bird with 26,000 miles. Last year it wouldn't start while at the dealer getting an oil change. They found a blown
fuel pump fuse. It happened twice since then - I replaced the fuse and all was OK. Now the car won't start at all and the fuse is OK. I am guessing the
fuel pump finally went? or is there another issue? Would like to hear from any folks with similar experience before I go to the dealer and get soaked.
Chip; More info I'm finding for you:
One guy says:
There were reports of problems with some 2002 Birds having problems similar to this. The
gas tank is a saddle tank that straddles the drive shaft tunnel and there are 2
fuel pumps, one for each side.
Another:
Something I learned. The electric
fuel pumps that Ford uses are located in the
fuel tanks and are partially kept cool by being submerged in gasoline. Keep your tank partially filled at all times because when you run low on gasoline your
fuel pump is running hotter than when it is totally submerged. The gas gauge is
part of the
fuel pump and if it doesn't work, you have to replace the
fuel pump to get a new gas gauge. But if you fill the tank up,say
evry 150 miles or so, your
fuel pump is happy.
Last one:
A former service advisor says - low fuel in the tank could cause a pump to burn out as the 2nd pump relies on the fuel to keep it cool.
Chip, this is the last
part of my research for you:
From a, ex-service advisor:
If your dealer was able to verify your concern and unable to correct all they have to do is call Ford's "Tech Hotline" and they may have the answer.
If not ask if they have a "Flight Recorder" (small computer with a button you push to capture events) that they can put in your car and let you dive it and capture the events in real time. heck if they can find then they can send a copy to the Hotline and the Engr's can review. I checked Oasis and there is no TSB or SSm's at this time for this problem.
Another says:
The pump control module monitors the fuel pressure and sends signals to the pumps that results in maintaining the required amount of pressure to the
injectors. I believe it is 38 lbs.
Another:
I've had my T-Bird about seven months now, the first month...gas sensor went out, burnt up
fuel pumps, stranded wife....dealer fixed.
Same guy:
The dealer called said the
fuel pump had gone out again! In just 4 mths. I asked why, "Well human made
parts..blah blah blah..." so I asked for the service manager, who was nice, he said he would call Ford to inquire what to check other things/causes...I just dont know...two times the
fuel pumps gone out in four mths...
And he finally got:
The Service Manager called me back said thay had done performance/voltage etc. tests on the car, all is well, ford said the problem simply is the
fuel pump and yes, its on warranty.
