G
Gene Woodrum
- 2
- 2004
(02/08/16)
My battery in my 04 with 85k was so low the car would not start. I noticed the running lights and tail lights were on but very dim. The switch on the dash was in the off position. AAA jumped me and I went to Sears for a new battery. While driving I realized the turn signals didn't work and the headlights came on only in the auto position although I can turn the running lights on with the switch. When I tried to use the turn signals the dash lights would go out. Sears said the battery was fine and sent me home.
He suggested I remove the cable from the positive post on the battery so I would not drain it tonight. I did disconnect it and reconnect it several times before leaving it off for the night hoping it might reset something but nothing changed. Any suggestions before I take this into the dealer.
02/27/16
I took the car to the Lincoln dealer here in Gainesville Fla on 2/18. They still have it. They replaced the switch in the steering column. ($650) then the FEM. ($800) Now I am waiting for a new instrument cluster to arrive for installation. ($1500) They tell me each time they replace a part the operation of the lights and blinkers change but not correctly. They have 2 master mechanics on the job and they are conferencing with Lincoln engineers. They can not tell me with any certainty the parts they have replaced are bad. Even if they were damaged they are not the solution and they have no idea why all of this has shorted out at the same time. At first they could not get the codes but Lincoln sent them an interface that allowed their computer to retrieve them.
This is my daily driver and with the car rental it is getting close to $4000. I am seriously considering telling them to take the new electronic parts out, put the old ones back in and pay them for the labor involved. The headlights will work in the auto position and I can drive the car using hand signals. Any thoughts or suggestions?
MODERATOR NOTE- VIEW THIS THREAD- https://forums.fordthunderbirdforum...d-front-electronic-module-fem-2002-2005.5560/
02/27/16
