1955 turn signals not working | Ford Thunderbird club group 1955-2005 T-Bird models
  • Thread starter Thread starter dicklhittt
D
I have had to replace my ignition switch. My turn signals don't work. What post on the switch should they be connected to? Do they need a fuse?
All three years use the same switch and the wires are connected the same. The wire numbers are found in the manual and references the color codes that are found on the wiring harness. The back of the switch is marked as follows:
BATT- #21 yellow wire, supplies voltage to the switch.
ACC – #30 black with green – fuel and temp gauge, #8 orange with yellow – turn signal, also attached is other accessories radio heater, etc. Note: Some accessory wires do no have rubber molded ends. The wire goes straight to the eyelet.
IGN – #16 red wire with green attaches to the coil on a 1955 and to the ignition resistor on a 1956/57, #30A,30B black with green wire attaches to oil pressure and generator light. The eyelet is single with the wires clustered together.
ST- #32 (the center post) Red/blue wire is energized when the ignition switch is held in the start position. It supplies voltage to the starter solenoid which engages the starter.
Also, don't forget to check the 15 amp fuse located between the ignition switchand the turn signal flasher.
