1970 turn signals stop working when headlights are turned on. | Ford Thunderbird forum club group 1955-2005 models
  • Thread starter Thread starter Paul70bird
P
Paul70bird
1
My 1970 Bird's turn signals work great all day but when it got dark and I turned on the headlights (which work fine) they stopped working both front and rear turn signal. Where should I start to figure this out.
Thank you
Thank you
Does your T-Bird have the original green or red flasher can (marked 4-lamp sequential trigger)?
If so, it may have aged so that it needs more current to flash than when new.
The headlights draw enough additional current so that a weak charging system or battery cannot provide enough current.
The original alternator barely provides enough for the headlights, turn signals, ignition, heater/AC fan, and accessory requirements.
Try replacing the flasher can with a new electronic flasher, such as the D0WY-13350-AR.
Vic, thank you so much for the lead on finding a fix for this problem. I have ordered the flasher and will see if this solves the problem.
Paul Curry
Cougersunlimited, found time to tackle the replacement of the rd flasher can yesterday. Bought and used to electronic device you suggested and it worked just perfect. Thank you again for your assistance.
