Frankie the Fink
- 476
- 2002
OK - my 25,000 mile, one owner 2002 TBird now has the climate control acting weird, in AUTO or MANUAL, DUAL or SINGLE, the heat will only blow with the temp over 82* and below that its A/C. You will freeze if its 62* out and you set the cockpit temp at 74*. I already changed the "ambient air sensor" behind the small grill in the dash near the ignition switch - didn't help...
The dealer says its the evaporator discharge air temp sensor (a $25 part) but it'll cost $1,500 labor to replace it and requires the instrument cluster to come out, yada-yada. Ridiculous. The Workshop and Service Manuals identify the part (which I've ordered) but no procedure to replace it...the part is apparently up inside the right hand side of the driver area in the evaporator somewhere.
Any insights or experience are appreciated...I searched the forum and found almost nothing on this issue...
