Forum Moderator
Staff member
- 1,130
- 2003
We're getting a lot of A/C posts on the forum, so I am going to start a thread. I'm not a mechanic, so please feel free to add your suggestions and recommendations for various scenarios. These recommendations below are based upon prior posts on the forum from Ford Thunderbird Owners.
A UV Flashlight and dye from Tracer Products is helpful!
Click here for prices on Amazon.
So a leak detector is handy! https://amzn.to/3MJ0wPT
Common Scenarios
- Blows hot on the passenger's side and cold on the driver's side is a frequent one or one side. This is usually the Dual Coolant Control Valve.
Installation photos here- https://forums.fordthunderbirdforum.com/threads/2002-dual-coolant-control-valve.6993/post-56530
This part can be confusing when ordering because the model years listed for Lincoln LS and Thunderbird vary and are sometimes confusing. The 2002 Thunderbird using the on with 5 ports and the 2003-2005 uses the one with 3 ports. That's how you know which one to order.
2002 Five Valve DCCV Replacement part
Purchase on Amazon here - https://amzn.to/3rzlciP
Purchase on eBay Here- https://www.ebay.com/sch/?kw=EHV103&campid=5338236430
2003-2004-2005 Three Valve DCCV Replacement part
Purchase on Amazon here- https://amzn.to/2VcyZj1
Purchase on eBay here- https://www.ebay.com/sch/?kw=XR840091&campid=5338236430
- Blows Hot on both sides. This can be caused by several things including low refrigerant, bad compressor, etc. The Climate Control Module is also often the culprit. You can either buy a replacement module or there is also a listing for a repair service for the unit. Click here for prices.
-AC low pressure port location
See below. @312 also posted some good photos on this thread. You can buy Ac Pro 134a refrigerant here which helps seal small gasket leaks.
If you want to DIY check out this R134a R12 R22 R502 AC A/C Manifold Gauge Set 5FT Colored Hose Air Conditioning
Purchase Link: https://amzn.to/2IyU4gC or (Purchase on ebay click here)
2002 2003 2004 2005 Ford Thunderbird Compressor Kits- (Purchase on Amazon click here)
If you want a the OEM Motorcraft compressor click here for Amazon or click here for Ebay
2002-2003-2004-2005 Ford Thunderbird Evaporator Core
Purchase on Amazon.com click here
Purchase on Ebay Click here
2002-2003-2004-2004 Evaporator Discharge Cabin Air Temperature Sensor
Purchase on Ebay Click Here
02-05 Ford Thunderbird Climate Control Air Temperature Sensor XW4H-19C734-AB OEM
Buy on eBay Click here
2002-2003-2004-2005 A/C Refrigerant Liquid Hose UAC HA 111547C and Motorcraft YF-2888
OEM Motorcraft YF-2888- https://ebay.us/LqKDpw or Amazon- https://amzn.to/3jnXR0e
Generic- https://ebay.us/ghQozM
Common Scenarios
