Window bump - up | Ford Thunderbird forum club group 1955-2005 models
Window bump - up
  • Thread starter Thread starter war_rat
Question, when it gets hot out my 02 Tbird's driverside window does not drive back up to closed. So, I drive around with the dinger going and my door ajar light on. Dealer is talking regulator ($175.00) and install ($100.00 not - I would do it) but I am just not sure. "Anyone" else out there had this problem? So to not confuse anyone, you grab your door handle and your window drops that little quarter of an inch to miss weather stripping, you get in and it jumps back up to seal..........Mine is not doing that. Thanks for any help.
That has happened to a lot of owners, especially on the drivers side.
Before you take it into trhe dealer again, your best bet is to reprogram the window as shown in the operators manual. This has worked for most people that reported this problem.
Recalibrating the side window
My latest thought was that you may not have the operators manual, so I just found a pdf file for you. See below:
