analogue_dsp
- 1
- 1959
It was a nice day out, so I went to fill up the old girl with gas. After, at the pump, I decided to put the top down. I was told by the previous owner to always have it running to help the pump out when putting the top down. So...started her up and then took my time opening the back up and extending the rear trunk. Started the top down and got about 1/2 way when I heard a "click click click" and the car shifted itself into reverse from park all by itself. I jumped over the closed door, grabbed the ebrake with all my might, and pulled. Car had gone about 15 ft. before I stopped it. Thank god no one was in the way.
Cracked a rib landing on the drivers window which was open about 2 inches. After checking to make sure the TBird wasn't actually a Plymouth Fury in disguise, (as in 'Christine') I looked this up online, and it is a common occurrence because of the design. I went out and tested this theory, and sure enough, occasionally the car does shift from park to reverse when running after a minute or two. I had previously noticed sometimes it doesn't always go into park, but into reverse, but didn't think it would slip. Good to know. I have a few questions:
1. Has anyone solved this issue such that a parked car stays in park when running?
2. Are there other "gotchas" I should know about this model? This one seems like a pretty big one which could have easily killed someone or worse yet damaged the car (j/k).
3. I now have a crack in the drivers door glass. I found it cheap enough online, at "Macs" but not sure if they are a reputable store or not. Is there a list of approved sellers you all keep?
