Tyler Townsley
- 2
- 1955
Having not found much good information on installing a T-5 in a baby bird I will post my journey to put a T-5 in my 55.
First go here and know your t5’s:
http://vb.foureyedpride.com/showthread.php?22730-difference-between-a-4-banger-T5-and-a-v8-T5-tranny
There are currently 2 vendors who offer an adapter to put an early T-5 behind a Y block. Do a search on Google to find one.
The early T-5s can be upgraded with later internals to avoid the problems associated with the early versions (which are the ones used with the adapters).
There are 3 methods to make this conversion.
If you use the stock driveshaft end you will need a Dana crossover u joint as the stock yoke uses an inner clip and most T-5 yokes use a 1330 outer clip u joint.
Things to look out for:
1 U joint clearance at transmission tail shaft. There are 2 u joint sizes used with the T-5 yoke, a 3 ¼ and a 3 ½ you need to make sure the joint clears the x frame.
2 The stock driveshaft yoke uses an inner c clip u joint end so you can either change this end when you lengthen the shaft or use a crossover u joint. Most parts guys have not got a clue, best thing is to take the t-5 yoke to the guy who lengthens the shaft.
3. The stock u joint on the rear end is special so make sure you do not change this without changing the yoke on the rear end.
It REALLY makes a difference.
Tyler
- When doing a body off install the drive train before dropping the body. (You will need to cut the tunnel to clear the shifter part of the transmission. You will be able to see where this cut needs to be made from the pictures I post.
- Install the transmission with the engine. Again the floor will need to be cut to clear the transmission shifter. Although the trans is 3 (watch out the adapter adds 1 inch) in shorter it is a tall transmission so it will be a tight fit.
- Leave the motor in and pull the transmission and put the adapter/T-5 in that way. This is what I did and would not recommend this approach as you have to cut the tunnel to get enough clearance to slide the trans back to get it in the bell housing. As you can see from the pictures I made a series of cuts before making the hole large enough to get the transmission into the bell housing. (The rear cut needs to be about 12 rear of the stock opening, and the frount needs to be about 10 in to the front of the opening.)
- Pictures at: LINK REMOVED, does not work. Upload photos to your post.
- Make sure you have the correct input shaft see above.
Tyler
