power trunk | Ford Thunderbird forum club group 1955-2005 models
power trunk
  • Thread starter Thread starter miketamu
M
miketamu
10
Has anyone attempted or completed a conversion of our 02-05 Tbird manual lift and close trunks to either electric cylinders with actuators or hydraulic cylinders with a pump?
If so, what electric or hydraulic parts did you use. I have a custom body shop that is willing to do the work. It won't be cheap, but it'll be cool and convenient - IF it works right.
Thanks
Mike
Mike, unless there's some physical impairment there's little ju$tification to do what you suggest. However, that's not to say that "cool and convenient" isn't highly appealing to most of us. There's no reason why a good custom body shop couldn't figure it out. Convertible top components should be adaptable. Hydraulic cylinders and pump parts probably less than $500. Good Luck!
Thanks
Mike
Only problem I had with mine was the runk started to have problems staying up so I just replaced the struts/lifts, fine after that.
