Well I'm no expert but I have worked in the machine shop almost all my life. From what I've heard here there could have been one of two problems with this.
#1. The casting was machined wrong.This can happen if they use a fixture to mount the casting on and the fixture was indicated in wrong or the boring bar or reamer was bent just a little and made the hole a few thousand's over size. Or egg shaped. This is not too hard to do but should have been picked up on after the first few pieces ran.
#2 Another reason, what I think it could be, is in recent years companies started doing what is called hard turning. This is when they take a
part that use to be ground and is now turned on a CNC lathe. It does work most of the time and is very cost efficient but it doesn't always work. Some times you just have to take the time and grind the
part. I have not seen anything that was hard turned that had the same finish as a ground
part. It comes down to the point ,is it good enough to pass this way. (Money is everything)
Just my opinion after working in a machine shop for almost 25 years.
02 T-Bird 9293
69 Vette
73 MGB
97 F-150 4x4
2-Seadoo Jet Skies
