Bob, sorry to learn of your lamp problem, but it is an easy fix. You don't even need to remove the shifter knob. It will be easier if you do move it down into drive position.
Then with a very thin tool like a very small screw driver you need to remove the curve plastic panel that holds the heated seat switches. This is done by gently lifting a corner at at a time. Gently is the key word because this piece is only held in place by 2 very fragile tabs. Once this piece is up & moved slightly out of your way, no need to disconnect the wiring, the entire center console cover can be pulled up as far as the shift knob will allow and you can get to the bulbs.
The cover is held in place by clips, it just pulls upward is loose.
If however you want to get the shift knob out of the way entirely you can easily do this by sliding the ring collar down the shifter which will reveal a set screw, loosen & pull the knob up. Again, the shifter has to be out of Park to do this.
If you run into trouble message me.
