Meyers:
I've been doing some research to try to help you. Here's some interesting info that may help from a service guy down in FL:
"04 Bird, I just ran Oasis and only came up with one SSM that covered both the
Check Engine Light &
ABS Light. With out knowing the DTC KOER/KOEO codes this is only a guess.
SSM 17338 - 2003-2004 Lincoln LS & Thunderbird - DTC P2106
Some 2003-2004 Lincoln LS & Thunderbird vehicles may exhibit diagnostic trouble code (DTC) P2106 (Throttle Actuator Control Systems - Forced Limited Power) Stored in the
PCM. This condition maybe caused by a concern with the Anti Lock Brake System (ABS) or an SCP communiation fault. To service first check for DTC's related to ABS or SCP communications faults as necessary following the appopriate pinpoint test in the
workshop manual. If DTC P2106 is still present, proceed with normal diag using the electronic version of the PC/ED manual
ALSO:
SSM # 17740 22003-2004 Linc LS & Thunderbird - Electronic Throttle Control Warning Message or Lamp On MIL On with DTC - P2106 - Possible Driveabilty Systems.
Some 2003-2004 Linc LS & Thunerbird vehicles may exhibit the "ETC FAILSAFE MODE" Warning displayed in the message center (3.9L) or the amber electronic throttle control warning lamp (3.oL) on and the malfuction indicator lamp (MIL) on with the DTC p2106 in the
PCM. Driveability systems may include rough idle,poor acceleration and lack of throttle response. To service reprogram
PCM with the latest calibration avilable using WDS release B30.10 or higher. Calibration files are also available at
www.motorcraft.com
04/26/2004
Either way your going to have to bring your vehicle in to check the codes in the system."
