ywlbird Welcome!!!
😎 Hopefully some of this data that was passed on to me will help:
08/19/02
DRIVEABILITY - ENGINE RUNS ROUGH OR
HESITATES WITH POSSIBLE MIS-FIRE DIAGNOSTIC
TROUBLE CODES (DTC) P0301-P0308 - WATER
CONTAMINATION IN
SPARK PLUG WELL - 3.9L
ENGINE ONLY
FORD:
2002 THUNDERBIRD
ISSUE
Some vehicles may exhibit an engine misfire or rough running condition. The Malfunction Indicator Lamp (MIL) may be illuminated with one or more mis-fire Diagnostic Trouble Codes (DTCs) stored. This could be caused by water entering the
spark plug well area of the engine. This may occur after the front of the vehicle or engine compartment is exposed to an abnormal amount of water. During this condition, water could pass through the protective convolute on the engine wire harness and eventually drain into the
spark plug wells.
ACTION
Remove a small section of convolute from the effected Ignition
Coil wire harness allowing any water that may accumulate to drain away from the
spark plug wells in the engine. Refer to the following Service Procedure for details.
WARRANTY STATUS: Eligible Under The Provisions Of Bumper To Bumper Warranty Coverage And Emissions Warranty Coverage
OPERATION DESCRIPTION TIME
021602A Seal Ignition
Coil Wires At 1.5 Hrs.
Right Hand
Coil Cover
021602B Seal Ignition
Coil Wires At 1.4 Hrs.
Left Hand
Coil Cover
DEALER CODING
CONDITION
BASIC
PART NO. CODE
12B637 95
OASIS CODES: 608000, 608400, 608500, 608600, 609000, 609400, 609500, 609600, 698298
Copyright © 2005 ALLDATA LLC
Terms of Use
