CD/Radio problem | Ford Thunderbird forum club group 1955-2005 models
CD/Radio problem
D
Don Bailey
8
2005 Bird with intermittant problem with radio/CD switching to a MUTE status. Some days it happens constantly where one cannot listen. Sometimes it will go days without a problem. Mute is displayed on the radio display. Speakers seem to be fine--has anyone expierenced this problem and found a solution?
Ive had this happen to me several times but each time it was because I accidently hit the MUTE button on the steering wheel. It sounds like you have a more serious problem. I'd take it to a Ford dealer - they should be able to check to see if its a loose connection in the steering wheel or maybe the radio itself.
radio goes to mute
Wifes 04 bird recentlt started doing the same thing, that and the passener side blows heat in august (set @ 69 degrees).
If you find the resolution to the problem please share torque221@*********
Rich
torx:
You said "Wifes 04 bird passenger side blows heat in august (set @ 69 degrees). "
Use the search function above, lots of solutions posted there
Thanks Quickdraw, I didn't know that. He should join 😎
Rich
Rich: Did you resolve your heat issue?
