2002 2003 2004 2005 Ford Thunderbird Thermostat Housing Water Pumps | Ford Thunderbird club group 1955-2005 T-Bird models
Forum Moderator
Staff member
1,351
If you are having trouble with your cooling system on your 2002, 2003, 2004 or 2005 Ford Thunderbird here are some useful parts used in the repairs. Note, a 2002 Thunderbird has a different thermostat housing than 2003-2004-2005. The water pump & thermostat are the same. You can upgrade the thermostat in a 2002 Thunderbird to aluminum. I believe only plastic is available for 2003-2005 Thunderbirds. The plastic thermostat housings often need to be replaced every 5 - 7 years.
Several people have reported issues with the paper gaskets on the aftermarket water pumps. The water pump itself is okay, but you need the upgraded gasket sold separately.
2002-2005 Thermostat-
Purchase Link- https://amzn.to/4dbgVsW
2002 Thermostat Housing Kit Assembly Aluminum Upgrade Kit-
Purchase link click here
Please note, this is an "unofficial upgrade" from the cheap plastic bell housing that member @Wfg3 discovered. The seller does not show the part as compatible, but it works as noted in his post here- https://forums.fordthunderbirdforum...work-in-2002-2005-thunderbird.8852/post-56177
2002 Thermostat Housing Kit Assembly (Plastic)
Purchase Link- https://amzn.to/2MZYKMp
2003-2004-2005 Dorman 902-903 Thermostat Housing Kit Assembly- (aluminum upgrade is not available to our knowledge)
Purchase Link- https://amzn.to/2YElNBR
OEM Motorcraft Part 3W4Z8548AD (Recommended when available)- Purchase Link
All available thermostat housings, some include coolant reservoir- Purchase Link
Housing Gasket (If Need) Amazon Purchase Link - Ebay Purchase Link
See this page for more gasket details
Coolant Overflow Tank for 5W4Z8A080AA
Purchase Link
The Motorcraft factory tank is over 200.00! Purchase link
WATER PUMPS.
The water pump and the gasket is the same on 2002-2005, but the thermostat housing is not! Fel-Pro currently erroneously states this is for 2003-2005, but it will also fit the 2002! We have contacted them to get them to update their database.
2002-2005 Pro Gasket- This is better than the paper gaskets included with the water pumps
Ebay Purchase Link
Motorcraft PW448 2002 2003 2004 2005 Water Pump OEM-
eBay purchase Link or Amazon purchase link
Aftermarket 2002-2003-2004-2005 Water Pump (don't use the paper gasket)
Purchase Link Amazon- https://amzn.to/2N0h3ks or eBay purchase link
2003-2005 Water Pump + Plastic Thermostat Housing (Housing won't fit 2002)
Purchase Link
2002 Ford Thunderbird Radiator - Ebay Link
Hydraulic Cooling fan which was only in 2002- Ebay Link
2003-2004-2005 Ford Thunderbird Radiator- Ebay Link
If you have a 2002, this is the only year that has a Hydraulic Cooling Fan! Sometimes these cars will overheat when the Air Conditioning is on or other symptoms. Many times this is because there is a solenoid on the hydraulic fan pump that the pcm controls to speed up the cooling fan,
they do go bad after time, and miles.
These are hard to find and most people get them on ebay!
Hydraulic Fan Pump Actuator Solenoid Lincoln LS Thunderbird NEWTO OEM XW4Z3783CA
Interchange Numbers: YW4Z-8C628-BA , YW4Z8C628BA , XW4Z3783CA
Ebay Purchase Link:
You can read a related discussion here- https://forums.fordthunderbirdforum.com/threads/2002-overheats-with-air-conditioning-running.12252/
In the ongoing effort to stop overheating we replaced the plastic thermostat housing with the Jaguar aluminum. In the process we discovered a chip in the extension just under the hose clamp. It's holding for now but would like to replace it. We purchased the Ford Manual DVD and searched everywhere online and can't find a part number. The number stamped on the part itself is related to the radiator. Any help would be greatly appreciated!!!IMG_1284.jpeg
I search every Blog, troubleshooter page, info, manual, etc. I could find to try to fix the overheating problem that seems inherent with these birds. The solution I've come up with involves a lot of other people's ideas conglomerated into one. I take no credit here.
Here's what I decided to do:
Flush cooling system. Mine was totally clean. Not a drop of rust or corrosion.
Fill with 50/50 coolant, distilled water while car is off. Filling as much as possible in Radiator and overflow container.
Reinstall cap on radiator.
Start car.
Turn on heater, full blast, high heat.
Idle car.
Watch level in overflow. When it goes down add more coolant and try to keep minimum 50% antifreeze. The higher proportion of antifreeze the higher the boiling point of coolant. Read directions on coolant container. My opinion is to increase to 75/25 coolant to water since these cars run hot. It should raise boiling temp. to 265. READ DIRECTIONS ON CONTAINER.
When coolant level in overflow stops going down, put on a glove and squeeze the hose to the left of the radiator. Continue doing so. You should see bubbles coming up in OFC and you should see level of coolant go down in OFC. You are purging the air from the system. Put in more coolant. Keep the level where you can see it even though it's above MAX fill line. You have to see if the air is being purged.
When bubbles stop, run idle up to 2k for a few minutes.
Check coolant level.
Squeeze hose to see if air will come out.
Run car for 15 minutes with OFC cap off.
Turn off car.
PUT ADDITIONAL"o" RING IN OFC CAP!!!!!
Put cap on, let engine cool.
After engine completely cools check coolant level in OFC. If it is below MAX line add more.
With cap on OFC squeeze hose. If bubbles show up repeat steps.
It worked for me after struggling for a month and having the 'Bird overheat and get me stuck three times trying all different solutions. This finally worked. No more "bubbling" in OFC that looks like the coolant is boiling. No more overheating.
I hope it works for you.
Here's a video with some coolant system burping / bleeding tips on the "cousin car' Lincoln LS. Would be great for a member to make a Thunderbird specific video and send to us to add to our YouTube channel!
My 2003 T-BIRD is Overheating. I put it in a local shop that normally does good work. They said the Water pump was leaking. So I had them replace it. They also replaced the thermostat and housing.. Well it didn't take long and it Overheated and does so within 4 or 5 miles. I'm thinking the electric fan, it's fuse, it's relay or switch. I know the fan is expensive, like $1200, so hopefully its one of the other things. Any ideas what else it could be? Thanks in advance. Tom
Purchase Link- https://amzn.to/2Y7ccEl
Purchase Link
WATER PUMPS.
Purchase Link
Purchase Link
My 03 had head problems, they were shaved and fixed, then the Fan and sensor were replaced and then the thermostat
I recently replaced my Heater Control Water Valve and now I'm having overheating issue's. I've tried elevating the front end of the Bird, turning on the car, running car at 3000 rpm's for 30 seconds, letting it come back to idle then shutting it off. Then topping off the antifreeze. I've done this 3 times and it still seems I have air in the system. Are there any other ways to purge the system of air on these 2002 T-Birds?
My engine blew the head gasket, since it was replaced I am getting overheating The mechanic says the hoses were damaged by contamination and wants to replace them all and the overflow reservoir Any advice on where to get the parts Is this really necessary it’s over1k! I Cannot find these hose parts 3W4Z 9F814AA & 3W4Z 18472AD
My car blew the head gasket since it was replaced I am getting overheating The mechanic says the hoses were damaged by overhand wants to replace them all and the overflow reservoir Any advice on where to get the parts Is this really necessary it’s over1k!
Personally that seems like a really dumb diagnosis. I would make sure the coolant was burped properly. These cars are much more difficult to get the air out than most.
See video above.
Had same problem. Replaced water pump, thermostat, no joy.
Problem turned out to be cracked reserve/overfill unit. Replaced. End of Problem.
Opened the overflow container when purging?
In the ongoing effort to stop overheating we replaced the plastic thermostat housing with the Jaguar aluminum. In the process we discovered a chip in the extension just under the hose clamp. It's holding for now but would like to replace it. We purchased the Ford Manual DVD and searched everywhere online and can't find a part number. The number stamped on the part itself is related to the radiator. Any help would be greatly appreciated!!!View attachment 13619
I can't help with the part but I went through overheating issue for months with my 04 . Replaced the thermostat and seemed to fix but it was only temporary. Did a radiator flush and didn't help. Finally I broke down and took it to the shop and it was my water pump. Once replaced its been fine. Not sure if that's you issue but worth checking. The mechanic was confident the pump was the culprit base on just touching the hose. I dont remember the exact way but one hose was hot and the other cool which indicates the water was circulating in the pump properly.
I've owned this car since new and it throws a tremendous amount of heat. I guess a design flaw. My Jaguar XJL seems to be the same. Good luck if you haven't fixed yours.
Posting Parts Wanted/For Sale & Discussion in Wrong Forum
When changing out the Water pump did you find one like the original, with the plastic housing and o-rings that go into the block ?
I’m not finding any like that
Motorcraft, Duralast, all have no plastic. All replacement pumps that I can view on line appear to be one piece.
I’m actually in favor of the one piece unit with no plastic.
HELP. My 2003 tbird is overheating. Mechanic says that he has put in a new thermostat, coolant motor and coolant tank. As long as the heater is running a full speed it isn’t overheating BUT as soon as he turns down or off the heater then the car starts to overheat again.
The radiator was replaced recently so not sure if that is the problem but he doesn’t think so.
He has bleed the coolant system so that’s not it. The thermostat was from O'Reilly and so now we have ordered one from Ford and going to replace the one from O'O'Reilly with the Ford part and hope that solves the problem.
Anyone else had the same problem, he is at his wits end.
Was the thermostat housing replaced? According to what I have read, the plastic T-stat housing is more likely the culprit: The t-stat retaining "nubs" in the housing break or wear away allowing the t-stat to be dislodged and not operate fully. IMO, one of the symptoms of this would be feeling warm air through the heat ducts faster than normal as the coolant either flows around or through a partially stuck open t-stat. I am not sure if the Motorcraft housing is still available, but I know the Gates housing is available and is made in Germany - so I would think it would be better than something like Doorman.
Had an overheating issue last summer after replacing thermostat housing with a new Dorman which includes thermostat. Probably a rare thing but thermostat itself turns out was defective! Was lucky enough to find a Motocraft one on line replaced and issue solved. Found it interesting that thermostat was manufactured in Great Britain, I would assume for Jaguar.
We have replaced the thermostat, coolant motor, coolant tank, radiator and blead the system. It doesn’t overheat as long as the heater is running at full speed but as soon as the heater is turned off it starts overheating again. My mechanic is about to give up. Has anyone else had this problem?
As already mentioned, inspect the thermostat housing as well.
At the end of the day, it's the mechanic is responsible for fixing the car. If they are well qualified, they should be able to test parts and determine the problem. If they cannot fix your car, find a mechanic who can. Sounds like you've replaced parts that didn't resolve the issue!
The heater running at full speed is irrelevant. When you run the heat on any car it helps cool down the cooling system as it is releasjng heat.
Good info here, and many thanks to Biddle for posting sources for parts and pictures.
My 03 with 84K sprung a coolant leak behind the water pump. Not sure exactly what part yet. When the system is under pressure it leaks, if I leave the degas bottle cap loose it doesn't leak. In the short term until I investigate what part I need, is it OK to drive with that cap loose? I assume the boiling temperature will go down. I did drive it around town that way, some stops and restarts. Ambient air temp in the 70s. Temp gauge in middle like normal.
Does anyone have any concerns about leaving a degas bottle cap a little loose?
