D
drhinckley
UPDATE EMAIL ADDRESS
I tried the Terk XM direct then found out that it won't work on my 05 Bird. I still have a Roady 2 that either connects via an audio output (mini-stereo jack) or RF output. I mounted my antenna behind the armrest on the console with velcro and hid all wires inside the console. I also used a little bit of velcro to secure the receiver to the blank panel in front of the shift lever. I use the RF out feature and one of my presets on my head unit tuned to it. What I need, and I hope someone can help, are the two blade pins that go into the 24-pin harness that supply power and ground for the Sirius radio. I want to hard wire a power supply for my Roady 2 so that it powers off when the radio does. If someone can even give me the name of the plug manufacturer that will help.
Doc in Central Texas
