S
Sharps40
- 45
- 2003
Troublesome to work on, especially with no dip stick but if you're sure your transmission is full and just want to do some refreshing. The job can be done in the drive way over a couple of weekends.
Supplies:
Torx bit and wrench for transmission drain pan center bolt.
Metric allan wrench socket, universal joint and 3/8 drive ratchet for transmission fluid fill plug on the extension.
Jack.
Jack stand.
6 qts favorite brand transmission fluid.
Quart bottle transfer pump.
2 to 4 quart clear container that fits under the transmission, car jacked up so you can access it.
2 to 4 quarts water.
Measuring cup marked in quarters or eights.
Black or favorite color sharpie pen.
Shop towels.
Start with a quart of water, put it in the clear container.
Make a sharpie mark and label 1 qt.
Add a quarter or half quart, make a mark.
Add a quarter or half quart, make a mark and so on until you have a home made measuring jug of the capacity you desire.
Empty and dry out your container.
Drive to walmart or your parts store and get your transmission fluid and a 1 qt bottle transfer pump.
I picked up this one at Walmart under $6.5 with taxes.
Come home, park your Thunderbird and let it cool down completely.
Set your parking brake. Chock rear wheels and raise the driver side front until you and your measuring container can get to the transmission drain pan plug on the drivers side of the pan. Use your jack stand.
Put the measuring container in place under the drain plug and use the torks bit and wrench to remove the center drain plug. Best to do this cold as it'll come gushing out and hot oil will make it near impossible to reinstall the center plug without getting scalded.
Watch the measuring container fill and before it gets to the level of oil you wanted to remove, put little drain plug back in the big drain plug.
Check the level in your catch pan, drain more if you like.
The level in your pan won't be super accurate but close enough because if your carefull you'll have some fluid on your hand and the rest in the measuring container.
Remove the measuring container full of old fluid.
Wipe up any mess.
Lower the drivers side.
Raise the passenger side front. Use your jack stand.
On the trans extension, passenger side rear of transmission, above the exhaust and the trans mount you'll see a pipe plug.
Use a 3/8 ratchet, a u joint and appropriate hex socket to remove it. Trans fluid is now low, passenger side is up and you shouldn't see more than a few drops come out the hole when you remove the plug.
Assemble the transfer pump on you selected bottle of fluid, insert the hose into the port you just removed the Allan headed fill plug from. Pump in the same amount of oil that you just drained into your measuring container.
Using the 3/8 ratchet, u joint and allan hex bit, reinstall the pipe plug and wipe up the mess.
Remove stuff from under the car.
Lower the passenger side. Remove wheel chocks.
Put away the tools.
Go for a test drive.
A bit of effort, about 30 minutes work and saves you an expensive trip to the Ford Lincoln dealer.
You could do this several times or just change 2 or 3 quarts with every motor oil change to really keep the fluid in a fresh state.
Supplies:
Jack.
Jack stand.
Shop towels.
Wipe up any mess.
Put away the tools.
