cursorofold
- 1
- 1978
I have a 2003 T-Bird with select shift. It has a problem with the dash indicator that is supposed to indicate what gear the shifter is in (normally "D5"). After I drive a couple of miles, it switches to an "E".
The local Ford dealer has replaced the instrument cluster and the shifter. They appear to have no real understanding of how the system works.
Has anyone else seen anything like this? Does anyone know how this system functions? I know it is not as simple as a cable going from the sensor to the dash. In order for the select shift system to know what gear I am currently in, it must have inputs from the transmission.
I have tried driving in select-shift mode, or just leaving it in drive. Either way, it swtiches to an E after going a mile or two. Aside from the incorrect dash display, the car drives fine.
Related question: Ford has disassembled my dash and my center console more than once, and it now rattles. The aren't done yet, but once they are done, I had planned to ask them to make the rattles go away. Can I reasonably expect them to succeed? Or does taking it apart inherently make it loose and therefore prone to rattle?
