C
classicfordguy
- 7
- 2002
Hey, folks. I'm new to the forum, and look forward to gaining some knowledge, and also sharing some at the same time. We have a 2002 Bird with the Premium Trim package, with about 22,000 miles. We got it new in July 2002 in Charlotte, NC. It was purchased from Harrelson Ford.
Anyway, the reason I joined your forum is that I need some help. The power steering pump has started to leak from the shaft seal. I have purchased an aftermarket pump, and started working on it today. I am using a Ford Factory manual for guidance. Before I go further, I'll let you know that I'm not a rookie. I started twisting wrenches as a teen (I'm 57 now), have worked on NASCAR race cars, and hand built 2 Classic Mustangs.
According to the book, after removing the 4 bolts in the AC Compressor, it says to move it out of the way. This is where the problem lies. Without removing the AC lines, I can't get enough slack to move it out of the way. There is a little tab on the lower block area at the edge of the oil pan. If this were gone, it might make things easier. But, I'm not going to saw it off! Does anyone have any suggestions how to move the compressor far enough without discharging the AC? Any help will be greatly appreciated! Thanks!
