vermbird
- 14
- 1960
tried to remove the coil spring front on my 1960. got it jacked up sway bar off, shock out. cannot get the lower bll joint to budge so i can lower the lower control arm and let spring out. my modern ball joint tool wont work. the shop manual calls for a special tool #T57P-3006-A it expands as you tighten a nut and then preesses on th stud of the upper balljoint and stud of the lower ball joint, freeing it as you whack it with a hammer. anyone have other ideas? the car is up on jack stands in my driveway. i dont want to dive up and take it to a shop.
