T
twright
UPDATE EMAIL ADDRESS
Started having a problem with the AC deciding on its on after 30 minutes of driving to magically go to full heat on the driver side. The passenger side is normal. Then after about another 10-15 minutes the passenger side decides to go to full hot as well. Only does it when the weather is somewhat warm (>60 degrees) and only after driving 30 minutes. And of course it doesn't do it everyday. Once it starts you can not override it. I end up turning the AC off and opening the windows. If you stop the car and restart it will reset.
The dealer "suspects" that the AC module (the part in the dash with the controls) is the problem. Wants $500.00 plus labor. I haven't found any hard codes set to show what is going on.
Anyone else have this going on? If so what was it?
