L
ls1bmw0
UPDATE EMAIL ADDRESS
3146 - MULTIPLE ELECTRICAL CONDITIONS
SOME 2002 THUNDERBIRD BUILT BEFORE 5/13/02 AND LINCOLN LS BUILT BEFORE 5/1/02
MAY EXHIBIT ELECTRICAL CONDITIONS AND DRIVEABILITY SYMPTOMS WHICH MAY BE
TRACED BACK TO THE MICRO-RELAY THAT PROVIDES POWER TO THE SUSPECT CIRCUIT OR
COMPONENT. THE FOLLOWING COMPONENTS MAY BE AFFECTED: WIPER SYSTEM, FOG
LAMPS, HORN, A/C CLUTCH, IGNITION COIL ON PLUGS, HEGO HEATERS AND FUEL PUMP.
TO DIAGNOSE, WIGGLE TEST AND LIGHTLY TAP ON THE SMALL MICRO RELAY WHILE
OBSERVING THE COMPONENT OR VEHICLE SYSTEM OPERATION. REPLACE THE RELAY IF
ANY SUSPECT OPERATION IS DETECTED DURING TESTING, PART NUMBER F5TZ-14N089-B.
REFER TO EV/TM, SECTION 11, FOR RELAY LOCATION AND CIRCUIT DETAILS.
