Need advice on 57 speedometer | Ford Thunderbird forum club group 1955-2005 models
  • Thread starter Thread starter dan1520
D
2
My speedometet in noisy and is jumping between MPH indicators. I haven't driven the car for a while and it's been sitting in the cold garage. I hate to remove it cause it's a bear to get behind the instrument panel with the seat in place.
Is there something I can spray inside the unit like WD40 and will that work?
Any ideas would be appreciated.
Thanks
A friend of mine suggested: "an answer though is to use white lithium grease to grease the cable, not WD40"
Additional info, FYI:
George,
Just talked to spouse and he said that he could also use graphite. They have graphite that is labeled for use on speedometer cables. He also said the cable must be pulled out to apply. No quick fix.
I agree, I had the same issue with my 65 Mustang, I had to uncouple the back of the cable using speedometer graphite. do it once the right way.
Thanks
Hi,
You might get lucky with lubricating the cable, which requires you to unscrew the cable from the back of the speedometer as mentioned above. There use to be a liquid graphite for speedometer cables, that I have not been able to find anymore. New cars don't have speedometer cables. I used liquid graphite for locks the last time I lubricated the cable. Hope that works for you because removing the speedometer is a real pain.
Good luck
Similar threads
