aidynphoenix
- 0
- 1986
Hello, Former owner of a 85 Cougar here. I Missed that car deeply, When i saw photos of this 86 TBird and the condition it appeared to be in, i had no hesitation in snatching it up. It is beautiful. it has 88K miles, Apparently owned by a little old lady. It has the exact same engine, paint and interior as my cougar had. 3.8L V6. White with Red Interior.
I am Thrilled. It is a lot of fun to drive around.
I did some typical maintenance, oil, fuel+oil filters, air filter, and radiator flush.
the car seemed to be surging a bit so i replaced the PCV valve and the missing hose going from the other valve cover to the intake and the idle seems to be normal now.
I want to keep this car in immaculate condition, and do several things to improve it if possible.
I replaced the factory stereo, and am waiting on some new infinity kappa speakers to arrive.
I deleted the antenna so my car cover would fit. also i don't listen to the radio.
I ordered a Summit 100-Amp single wire alternator to replace the crappy 60-Amp factory alternator.
The Headlights are very dull and i can see condensation inside, so i ordered some LED Headlights, I will see how those look when they arrive.
I plan to replace all the turn signals, tail-lights, and other bulbs (except for the dash lights) with LED bulbs. Hopefully they are brighter, last longer and draw less power.
I am trying to think of other things i can do to this car. I want to squeeze every bit out enjoyment out of this that i can without spending a ton or changing anything that i cant change back easily.
I was thinking about replacing the old Coil Springs, Struts, Shocks, End Links and anything else that is cheap and can use a polyurethane bushing.
The old tags expired in 2006, and it had been sitting since then, so it definitely needs tires.
I am not a huge fan of the hubcaps. while i think it looks nice, i prefer a more aggressive appearance and was considering new wheels. These were almost the only thing i could find that claim to fit, and were in stock. also are not too expensive. https://www.carid.com/vision-wheels/531-sport-lite-polished-81592944.html
They are however 1 inch larger.
I am also hesitant to buy wheels because i know larger tires will throw off the speedometer reading, and also i was thinking that a 5 lug conversion would not be a terrible idea, just in case i got crazy later down the road and decided to V8 this car.
Any idea how much larger tires will throw off my speedometer reading?
I am trying to track down replacement outer door belt seals for the windows. the originals are old and cracking a bit and i don't want to allow water to get into the doors.
the mud flaps are also about to fall off, i would like to replace those.
I am no automotive expert. any advice is greatly appreciated.
https://i.Attached your image to the post. postimg.cc not permitted./4HNHrGkH/20180922_085640.jpg
https://i.Attached your image to the post. postimg.cc not permitted./crzt5PD6/20180922_085655.jpg
https://i.Attached your image to the post. postimg.cc not permitted./mtkFjTy0/20180922_085709.jpg
https://i.Attached your image to the post. postimg.cc not permitted./gwFXG8bW/20180922_085756.jpg
https://i.Attached your image to the post. postimg.cc not permitted./hX7QFMws/20180922_090003.jpg
https://i.Attached your image to the post. postimg.cc not permitted./SjDMcnC6/20180922_091913.jpg
