H
hsiegl
UPDATE EMAIL ADDRESS
I have seen reports that mention high speed engine whine in the 2002 Tbird.
I take that as a good sign. The engine uses a timing chain and I hope they do not use plastic covered gears to reduce noise.
My son had a Dodge charger that had the plastic timing gear fail and that made the chain slip a couple of nothes. We replaced the gear with a solid steel one. Whine is better then plastic that fails later.
Does anyone know for sure that the timing gears are not covered with plastic or teflon?
hsiegl
hsiegl
