P
PhilK
- 1
- 1966
I need advise on routing the heater hoses on a '66 with AC. The shop manual states that the hose from the manifold goes to the water valve, so the hose going to the water pump should come from the other core connection, correct? I can't supply a picture as I have already removed most of the hoses. I think the previous owner had them wrong. He had the water pump connected to the valve. The intake manifold had a double connection, one hose ran past the carb and joined the other hose and connected to the core. As there is a Holley carb on it now, I don't need the choke heat hose and will eliminate the "Y" connector. Am I correct in going with the shop manual? Thanks
