FS 1966 Fan & Shroud. | Ford Thunderbird forum club group 1955-2005 models
  • Thread starter Thread starter BigClay
BigClay
BigClay
65
For sale: Almost New 1966 19” A/C Fan, Thermo Clutch and Custom Fiberglass one piece Shroud (“custom” because I made it 2” deeper than stock for better flow). Less than 500 miles on all. I had on my ‘64 but switched to electric fans so I don’t need anymore. $100.00 plus shipping. (I’m in IL).
Big Clay, Thanks but I think I am going the way you went with the electric fans. Can you point me to a good set up for electric fans and shroud? Did you keep you oem radiator or did you go aluminum?
I have an aluminum radiator (made for the Bird). I measured the core, and found a twin fan/shroud made by Drale that I got from Summit Racing. It fit perfect with minor trimming. Problem is, they pull over 45 amps when running. I also installed a 100amp Alternator with heavier wiring to handle the load.
Thanks for the info. I was concerned about the Amp draw. Nice work! I'll check out Summit for the fans. I'm sure your set up works better than original.
