H
Heavyfinger
- 0
I have a 2004 first owner and it is having a couple of issues. First of all it is really riding rough. Just put on a new set of tires and not much difference. She has 62,000 and it appears it is time for a new set of struts. I seem to have a slight rattle when the top is up/on that originates from the back in. I believe this is a strut problem. Can someone confirm such a noise? I have also begun to see smoke coming from the tailpipe but only if she sits in idle for about 5 minutes. Once you start driving this goes away. I heard that there is a filter inside the drivers side valve cover that gets full of oil and could be causing this problem. I have also been told that I may have a bad coil. My mechanic replaced 3 that he said the computer was showing as a problem. Should I have replaced all of them? Could this be part of the smoking problem. Sometimes on hot days or long drives she starts to chug a little when you try to step on the gas. Once she clears herself out.....ZOOM This happens whether you are in sport shift or not. Could all of these symptoms be related to the coils? Just some info that might help someone answer these questions. I will never part with her no matter what.
