convertible top head liner | Ford Thunderbird forum club group 1955-2005 models
  • Thread starter Thread starter 03TBird
19
any suggestions on sagging headliner, or just as easy to eliminate the headliner altogether. I tried spraying some glue substance, but could not get it far enough into headliner to make a difference
If you spray Contact Cement with a nozzle that accommodates one of those little red tubes thru slits, not holes, in the headliner it will work. Give it some time to dry before applying pressure. The slits should nearly disappear. You may have to swap some nozzles around to find one that accepts a tube.
