H
HorsePowerJunkie
UPDATE EMAIL ADDRESS
When the hardtop is on and the windows are up...
When you lift the door handle the window comes down slightly to clear the hardtop window moulding. Mine is not coming down timely, causing the window to drag in the hardtop window moulding.
The window does come down, just not in time to keep it from dragging. The driver's side works fine, the passenger side is slow to react causing it to drag.
Anyone else experinece this problem?
If so, what was done to correct the problem?
Many thanks,
HPJ
Many thanks,
HPJ
