2003 Window Drop Delay | Ford Thunderbird club group 1955-2005 T-Bird models
  • Thread starter Thread starter Bellhop
B
10
Hello, my passenger window doesn't seem to go down when the door handle is pulled. It takes me pulling on the door going against the seal for it to go down. On the drivers side door as soon as I pull the handle the window drops and I can clear the seal. I have tried the calibration method with the window switches but that doesn't seem to help. Do you guys have any ideas?
Thank you!
There is a passenger window adjust switch located inside the passenger door. I would begin by testing the passenger window adjust switch to determine if it is defective.
I have the same problem but it's the driver's door (but nothing will trick it into auto-lowering),
is this a different part number than the one on the passenger side?
Just like the passenger window there is an adjust switch located inside the driver door. Before you start testing the driver window adjust switch to determine if it is defective try recalibrating the windows first.
