66 repainting question | Ford Thunderbird forum club group 1955-2005 models
  • Thread starter Thread starter SpacemanSpiff
S
SpacemanSpiff
First time post... So I just bought my first t bird... 1966, Q code 428. Super excited and already planing lots of things. Question... Need to repaint it... And don't know much about the paint from the 60s. Can I spray a seal coat over it then spray base then clear... Or will I have to strip all the paint off??? (the old paint is fine... Except for a few spots I need to fix - bare metal showing etc..)
The way I painted my '63. I sanded it, primed it, color coated it, clear coated it, wet sanded it with 2000 grit sand paper then buffed it. It is quite a process. If you have never done that, try to find an experienced person to help or do it for you. All the necessary ingredients are pretty expensive. If done correct it is worth it.
In a previous life I did custom motorcycle painting... When metal flake and bobber were popular. I just have never done anything over older paint. I always went to bare metal so I knew what I was working with. This is completely different... And I REALLY don't want to take it down to metal! So I'll do my body work, high build primer, sealer, color, clear, cut n buff.
Thanks!
