64 rear windows slow/sticking | Ford Thunderbird forum club group 1955-2005 models
  • Thread starter Thread starter thunder2010
thunder2010
thunder2010
12
I have an issue with the rear widow being very slow and sometimes one will stop half way without help, I have taken the panel off and sprayed down all the tracks, it helped a little but are still not very good....anyone have any other ideas I can try?
I have had the same problem - only solution is to replace the motors. I can give you the name of a guy who rebuilds them, cost is $125 each compared with $250 for new.
Mm
Usually it’s a ground wire. Check all your grounds and make sure they’re secure.
you need to take the motors out and clean the old dried grease out of the gear housings and gears. put fresh grease in and they will work like new. labor intensive, but well worth the result.
Hello, My 61 has the same rear windows issue. I would appreciate the name of the rebuilder who services these elctrci motors.
Phil in Nashville
Agree with 57tbird57. Service the motors and replace the grease and hopefully you won't need a rebuild. It might be that the regulator mechanism is worn so recommend checking it for play.
I completely removed the window mechanism from the car, then thoroughly cleaned and regressed the tracks. Made a big difference.
