D
ddixon2327
- 0
- 1964
I have 64 Bird and the rear windows work intermittently. New motors in both, new switches, complete alignment of the windows that are perfectly in line either the weatherstripping. All wiring tested and 12 volts to all connections, ran a separate ground to one window and still same issue.
It seems the issue is the motor and regulator alignment whereby the four bolts holding the motor can be loosen and the one that is more difficult or binding will cause the motor to work and move the window properly.
Problem is a little while later it stops working again. Does anyone know of trick or ways to fix this problem!!!!!
